BigEars Posted February 23, 2011 Report Share Posted February 23, 2011 So earlier in the day, under acceleration, i thought i felt my clutch slip a little. Then, on my way home, my power delivery became very sporadic. i would lose power to the wheels, but sometimes my revs would drop to 0 and sometimes they would spike slightly, but not as if the motor wasn't under load. Any help would be appreciated. Oh, btw...I'm running a L18 with a 5 speed dogleg tranny and (i believe) a stock dif. Quote Link to comment
datzenmike Posted February 23, 2011 Report Share Posted February 23, 2011 Loose wire to the tach or loose wire in the ignition system. Coil, ballast, points specially.Is the dizzy bolted down tight and well grounded? Quote Link to comment
