dimedriver Posted December 12, 2015 Report Share Posted December 12, 2015 its called the Ford EDIS system. Most of the parts will be Found on late 90's escorts. Its computer controlled so you will need an extra box to run it. Megasqirt will do it I think there was a megajolt that only ran this ignition. Without a computer it will run 10degrees of advance if I remember right. Here is some info on it. http://www.megamanual.com/ms2/EDIS.htm https://www.autosportlabs.com/product Quote Link to comment
dimedriver Posted December 12, 2015 Report Share Posted December 12, 2015 Also if your intrested in doing this as a stepping stone to EFI the GM DIS system is similar and their computers(ecu/pcm) are very easy to reprogram. They can also run the ignition standalone with only a tps and map sensor. Quote Link to comment
