Hardbody Question...
68Datsun510
97 HB 2wd 2.4L
Hey folks, couple quick questions, anyone else have water dripping out o0f their heater fan? Its not coolant, cold, and clear water.
is this common or is it possibly a windshield issue? The push in strip on the top of the windshield ripped out.
Also, what the hell wrench do you use to remove the tension rods??? Want to install the moog bushing kit.
Thanks!!!
  • Replies 2
97 HB 2wd 2.4L
Thanks!!!
i would guess you have a windshield leak. look on the inside of the firewall as far as you can. you might even need to pull the heater. (or just have a new seal installed!!)
and doesnt the tension rod take like a 22-24mm deep socket??? been awhile since i tore down a hb......
Go figure, now my Hb AND 510 have leaky windsheilds...
And i couldnt believe it in regards to the tension rods, its the first time I didnt have the right wrench/tool to do something. I FAIL ;P
