Vacuum problem??
Sorry it has taken me so long to get back and give an update! Ok so here's what is going on..
I performed a compression check before anything else and read 140-150. Inspected some more for vacuum leaks and none still seem to be present..
I sprayed the carb down and made sure nothing was sticking or binding. Everything seems to be working fine but I was wondering if anyone had a picture of all the throttle linkage and springs etc..it looks like I am missing a couple of pieces as far as linkage goes but I am not positive
Thanks for the help!
  • Replies 27
Update: took the stock carb off and inspected further and found it cracked and very worn out...I also found out from a friend that I am indeed missing a linkage..I was able to find a rebuilt weber for $80 and I ordered the adapter plate. Thank you all for your help! It is much appreciated!
