Modded projectors
Up for sale are these beautiful BMW projectors. They have been modded to fit 9005 High-beam bulbs, and the insides have been polished for max output light. Both lenses only have minor pits in them. Better oics upon request. Lets say $60 + shipping. Includes ugly home made wiring/relay harness. (works great)
  • Replies 7
These a direct bolt on for the 620's? If so I'll take them.
Direct bolt? Doubtful that BMW has the exact same mounting spots as 620.
On a 510 its as simple as cut the mounting tabs off and use the 510 ring to mount. (wiring is something else)
Does a 620 have those mounting rings to hold in the light? If not you will need to JB weld some mounts on.
http://community.ratsun.net/topic/9323-install-bmw-ellipsoids-in-a-510/
  • 3 weeks later...
I've got a set of these on my 620, you're going to have to cut the headlight buckets down to about 2in plus you have to cut and smooth the tabs on the headlight itself, easily be done in a day or a couple hours.
