Radim Posted January 6, 2011 Report Share Posted January 6, 2011 Didn't know where else to post but i was curious if i can put air horns from an IDA/IDF/DRLA on my DCOMs, the DCOMs use the bolt-on type where as most DCOEs use the slip on type. DCOMs are exactly the same as DCOEs with small exceptions like the Air Horn fittings and a Diaphragm fuel delivery. or Where i can find a set of four for cheap? :) Quote Link to comment
69FJWagon Posted January 9, 2011 Report Share Posted January 9, 2011 Didn't know where else to post but i was curious if i can put air horns from an IDA/IDF/DRLA on my DCOMs, the DCOMs use the bolt-on type where as most DCOEs use the slip on type. DCOMs are exactly the same as DCOEs with small exceptions like the Air Horn fittings and a Diaphragm fuel delivery. or Where i can find a set of four for cheap? :) Mikunis use bolt on air horns... try wolfcreek racing Quote Link to comment
Duke Posted January 9, 2011 Report Share Posted January 9, 2011 Here are some cheap ones that are of the bolt on variety. http://www.piercemanifolds.com/category_s/172.htm Quote Link to comment
Radim Posted January 9, 2011 Author Report Share Posted January 9, 2011 Cool, thanks guys! Quote Link to comment
