Interchangeable Weber Air Horns?
Radim
Didn't know where else to post but i was curious if i can put air horns from an IDA/IDF/DRLA on my DCOMs, the DCOMs use the bolt-on type where as most DCOEs use the slip on type.
DCOMs are exactly the same as DCOEs with small exceptions like the Air Horn fittings and a Diaphragm fuel delivery.
or
Where i can find a set of four for cheap? :)
  • Replies 3
or
Mikunis use bolt on air horns... try wolfcreek racing
