dennis Posted December 29, 2010 Report Share Posted December 29, 2010 Well I am going with a inline fuel pump (walbro 225 lph) and wanted to make sure I can pull the fuel out to where I would not starve the engine for fuel. I was thinking about adding drilling a larger hole where the outlet nipple is and replacing it with an AN fitting. Any suggestions? I really do not want to take the tank to someone just to weld up a larger tube. Quote Link to comment
DISLEXICDIME Posted December 29, 2010 Report Share Posted December 29, 2010 Sodder it . You will need a sump or your engine will starv for fuel when you accelerate. The original tank does not have the baffeling . You need Quote Link to comment
dennis Posted December 29, 2010 Author Report Share Posted December 29, 2010 Sodder it . You will need a sump or your engine will starv for fuel when you accelerate. The original tank does not have the baffeling . You need Surge tank baby! Quote Link to comment
dennis Posted December 29, 2010 Author Report Share Posted December 29, 2010 I could run one of these and save some money http://www.jegs.com/...7/4041/10002/-1 This full race sump is the way I might go since I only need one outlet http://www.full-race.com/catalog/product_info.php?products_id=883 Quote Link to comment
