burrito213 Posted December 26, 2010 Report Share Posted December 26, 2010 does anyone want to spare or part out with their clutch boot/dust cover? its the rubber peice that goes in between the clutch arm to the slave cylinder pm me i have a tranny which i believe came from a 520 here are some pics. Link to comment
datzenmike Posted December 26, 2010 Report Share Posted December 26, 2010 You can also use the one from the '70-'72 521, '70-'71 240z car, '68-'73 510, the '72-'74 620s, all 610s, all 710s and all HL510s (4 speed only) All the same part number. Sure looks like it's for a J13 Link to comment
dat521gatherer Posted December 26, 2010 Report Share Posted December 26, 2010 part number 30542-21000 $2.63 and $3 to ship at nissanparts.cc https://ssl.autocenter.net/nissanparts/cart/?pn=30542-21000 Link to comment
burrito213 Posted December 26, 2010 Author Report Share Posted December 26, 2010 datzen mike... i wish i really knew. it is not for my truck and the guy that fixed my trannsmission said it was possibly something else. Link to comment
datzenmike Posted December 26, 2010 Report Share Posted December 26, 2010 I'll see if I have a picture of a known J13 tranny. Yes. If you look at yours you'll see that the center line casting on top of the tranny goes up to the engine and is equal distant from both bolts to the motor. If from an L series that casting line would be over closer to the left side. Also the 521 L series trannys had a flange on the output spline that is bolted on like this... . Link to comment
