Driftastic210 Posted December 12, 2010 Report Share Posted December 12, 2010 So the other day my blower quit working which i assumed it was the control switch since the blower is relatively new and i replaced the blower relay, but it still does not work. I just noticed tonight that my dash lights are also out. is there any chance that i have an electrical problem thats causing both of these problems. Ive check all fuses but all seem good. Quote Link to comment
Driftastic210 Posted December 12, 2010 Author Report Share Posted December 12, 2010 ok update i also have no parking lights, i discovered that the tail lamp fuse was blown so i replaced it, it popped immediately. Is there a FSM on the 210.... Quote Link to comment
datzenmike Posted December 12, 2010 Report Share Posted December 12, 2010 The running light fuse isnot used for powering the heater fan but it does go to the heater control illumination. If the heater was out to be replaced maybe a wire was pinched in the heater control lever area. Quote Link to comment
Driftastic210 Posted December 12, 2010 Author Report Share Posted December 12, 2010 well i got a short somewhere , no dash lights, no parking lights, and no blower. I keep popping tail lamp fuses. Quote Link to comment
TheCiscoKid Posted December 12, 2010 Report Share Posted December 12, 2010 Check your headlight switch, should control the tail lights and instrument panel lights, mine was bad and I kept popping tail fuses, but thats on my D21...the contacts get dirt, should be able to pull it apart and clean it Quote Link to comment
