Tail lights wiring
inda bebe
  • Replies 4
Do any of the running lights work? The cluster, tail, and front clearance lights are all on the same circuit. "Tail Lights" does NOT include Brake or turn signals... they're on separate fuses. If they are all out it's one of these:
1) Fuse
2) Fusable Link
3) Headlight Switch (which includes a relay inside the switch assembly on that year I believe)
Or a major wiring disaster.
1) Fuse
2) Fusable Link
the cluster doesnt blink at all. signal, hazard, headlights and high beams work fine.
ive checked the fuse, and thats okay, so ill go and check the other 2.
thanks, a lot for the quick replies.
