Ka24de swaped 510 - No Spark- No power to coil
blasta510
I swapped a ka out of a 92 240sx into my 510.
I had it running fine and then one day it just didn't have spark.
Replaced the ignition and it had spark.
Then out of no where it lost spark again.
It does not have power to the coil or the dizzy. When it did before.
I'm confused!
Edit*
Please move to electrical.
  • Replies 3
the blk wht wire is the ignition "ON" wire.
I will assume that you have this wire as the switchable Power to the other relays.
the blk wire wire goes to the stock fuse box so ck the fuse and connections there also.
if you have power on the blk/wht wire I assume the key switch part is good. Then I also assume you would ck your new fuse box you installed and ck the relays if it powers the ECU.
I know Im doing alot of assumming!!!!!!!!!!!!!1
