inda bebe Posted November 25, 2010 Report Share Posted November 25, 2010 i have a 86 720 and im gonna be doing a ka24de swap. Im going to be replacing the clutch, do i search a kit based on the 720's transmission or teh 05 240sx Engine? i hear that you can just slap the engine on w/ the 720's tranny, but searching for Exedy OEM clutch kit, its a different application. thanks, guys. HAPPY THANKSGIVING. Quote Link to comment
datzenmike Posted November 26, 2010 Report Share Posted November 26, 2010 i have a 86 720 and im gonna be doing a ka24de swap. Im going to be replacing the clutch, do i search a kit based on the 720's transmission or teh 05 240sx Engine? i hear that you can just slap the engine on w/ the 720's tranny, but searching for Exedy OEM clutch kit, its a different application. thanks, guys. HAPPY THANKSGIVING. Lets see if I understand this.... You have a 720 that will soon have a KA24DE motor and need a new clutch for this combination.. Get whatever clutch you want for the KA24DE motor... it has to fit the KA flywheel. Yes, the KA will bolt to the stock 720 5 speed. However the clutch arm holds a release bearing and collar that is matched to the 720's old clutch. It may not be compatible with the KA clutch, hopefully a new collar comes with the KA clutch. Quote Link to comment
inda bebe Posted November 26, 2010 Author Report Share Posted November 26, 2010 correct. im picking up a ka motor thats going into my 720. i wanted to change up the clutch since it was all coming off anyways. i just got lost to which i should be searching for. Quote Link to comment
datzenmike Posted November 26, 2010 Report Share Posted November 26, 2010 The 720 flywheel might fit the KA but any 720 225mm clutch/PP that would fit it is a bit light for a KA's power. The S13 KA flywheel I've heard will fit a Z or L series motor and are 225mm also and may be higher clamping force. However later S14s are slightly different I think. Quote Link to comment
