globe471 Posted November 2, 2010 Report Share Posted November 2, 2010 my uncle has a 73 automatic 620 and his flywheel is gone broke it has an l16b anyone have a 5 bolt flywheel they want to sell? Link to comment
MicroMachinery Posted November 2, 2010 Report Share Posted November 2, 2010 Are you sure you're not looking for a "flexplate"? -The torque converter in an Automatic transmission bolts to a flexplate. -The clutch/pressure plate in a manual transmission bolts to a flywheel. Which one is it? Link to comment
Chris#51EPGraham Posted November 2, 2010 Report Share Posted November 2, 2010 Yeah...I've never heard of a cast iron stick flywheel breaking. It could happen on a a 9000+ rpm race engine but can't imagine it occurring on a daily driver truck. Unless he broke the starter ring gear real bad. That happens. I have 5 or 6 L16 flywheels avail for $30 and $40 each (cheaper = disc surface needs regrinding) but shipping to Oregon would be pretty high. Link to comment
datzenmike Posted November 2, 2010 Report Share Posted November 2, 2010 my uncle has a 73 automatic 620 ..... Pretty much says it all. But it should be called a flex plate to avoid confusion. The '72 would have had the 'newer' Nissan 3N71B in it, same as the late 510 automatics. A 'flexplate' from a 610 or 710 auto up to around '74 should work as long as it is an L18 and not an L20B which has the six bolt mounting. Z cars used six bolt flexplates. Link to comment
Chris#51EPGraham Posted November 3, 2010 Report Share Posted November 3, 2010 Pretty much says it all. But it should be called a flex plate to avoid confusion. The '72 would have had the 'newer' Nissan 3N71B in it, same as the late 510 automatics. A 'flexplate' from a 610 or 710 auto up to around '74 should work as long as it is an L18 and not an L20B which has the six bolt mounting. Z cars used six bolt flexplates. Silly me..had a senior moment there...saw flywheel and blanked out automatic, lol. Link to comment
globe471 Posted November 3, 2010 Author Report Share Posted November 3, 2010 Are you sure you're not looking for a "flexplate"? -The torque converter in an Automatic transmission bolts to a flexplate. -The clutch/pressure plate in a manual transmission bolts to a flywheel. Which one is it? ok so its a 5 bolt flexplate Link to comment
globe471 Posted December 18, 2010 Author Report Share Posted December 18, 2010 Im still needing this 5 bolt flexplate, if someone has one i want it. send email to darioavilag@gmail.com Link to comment
izzo Posted December 18, 2010 Report Share Posted December 18, 2010 I was driving in my 89 ford ranger 4x4, auto. The flex plate shattered and sheered apart. Link to comment
