carl Posted October 28, 2010 Report Share Posted October 28, 2010 I need a gas tank and fuel neck for a 76 620 short bed shipped to 33024 florida. mine is full of rust thanks Link to comment
yello620 Posted October 28, 2010 Report Share Posted October 28, 2010 Can you ship fuel tanks that have had fuel in them?? I have one from a 75 shortbed with the filler neck too. Have not looked inside of it though. Link to comment
carl Posted October 28, 2010 Author Report Share Posted October 28, 2010 Can you ship fuel tanks that have had fuel in them?? I have one from a 75 shortbed with the filler neck too. Have not looked inside of it though. I'm not sure. Anyone know? How much do you want? Thanks Link to comment
datzenmike Posted October 28, 2010 Report Share Posted October 28, 2010 I need a gas tank and fuel neck for a 76 620 short bed shipped to 33024 florida. mine is full of rust thanks If no holes, drain and remove the sender/float and throw in several hand fulls of clean gravel and shake while rotating it to get all the insides. Don't be shy give it hell! Empty gravel and crap out the sender hole and hose out well. Remove fuel filter and blow out the gas line, let tank dry, install sender and install tank using a new fuel filter, add some gas line anti freeze to absorb any water left in, change filter after a few days and cut open to see if there is any rust trapped. Did this on my 710 when the filter would only go 20 miles at a time between changes. I have a clear see through filter from a honda or something on it now and after all summer it's clean as a whistle. Try to keep the tank full and use gasline anti freeze to absorb any rust causing water. Trick: go to Wall Mart paint department and get a quart/liter of methyl hydrate about $4? It's the same stuff used in those 3 ounce gasline anti freeze bottles they sell for a dollar. Should be enough for 10 tank fills. Link to comment
carl Posted October 30, 2010 Author Report Share Posted October 30, 2010 thanks man im going to try that. Link to comment
