MikeRL411 Posted October 27, 2010 Report Share Posted October 27, 2010 Those of us with older model cars and trucks with the brake light switch in the brake fluid distribution manifold, not a microswitch on the pedal, will eventually have to change it out. Either by age related failure or personal screwup [don't ask how I know] it will fail. You will need a special deep socket to remove and replace it, a standard 1 inch socket won't fit over the corners. You need a special 12 point deep socket K-D 1 & 1-1/16 part number 2569. Having owned and maintained my car for 43 years, I had one, -- someplace! I went to my local Kragen and looked but could not find one. I asked at the parts counter and you can guess what a blank stare I got in reply. As I was leaving, a newly hired salesgirl asked what I needed. I told her, why not, no help at the desk. She pointed to some newly stocked "GM Performance Parts" items and said they might have something close. It worked! A deep socket "Grips All" GM8309 was the answer, It is nominaly one inch but instead of parallel jaws it has a slight inward radiused face. The faces slip over the flats on the switch and as it turns the corners move into contact and remove the switch [and install the replacement] without cracking the insulator base. By the way, I found my KD socket and used the GM part to remove the old switch to be sure it worked, it did. I used the KD switch to reinstall the new switch since I had a half inch extension bar that was perfect to fit around the heater hoses. The GM socket is a 3/4 drive. 1 Quote Link to comment
