NCRmtrsprts510 Posted October 24, 2010 Report Share Posted October 24, 2010 got a box full of 510 parts came from a 1970.. local preferred - Gas tank (no filler neck) $40 - Radiator with hoses and cap $40 - Stock dash modified to fit auto meter gauges - no cracks! - $50 - coil - make offer - some resistor box thing - make offer - COMPLETE Throttle assembly including inside the cab - SOLD - speedometer cable (works with autometer gauges) - make offer - factory tire iron (i think) - make offer - hand brake assembly everything from the handle to the mount and cable leading to the crossmember - $30 - Hood prop assembly with spring - make offer - custom aluminum center part of dash (matches curves of stock dash) made to fit three 2-5/8" autometer gauges - make offer - Lug nuts - make offer I probably have some other parts laying around, if i find some more, i will add them to the list. please make reasonable offers and ALL prices are OBO! Also Got another box full of parts, ALL will fit CA18, Almost all parts came off of a CA18DET, some will fit both KA24 and SR20 . - T25 Garrett AR.48 / AR.49 Internal wastegate 8psi turbo - some play - $100 - T25 downpipe with o2 bung - 2 broken studs - make offer - CA18 Turbo manifold - if anyone even has a ca18 lol - Stock Fuel pressure regulator - fits all i believe - $20 - Power Steering Pump w/ bracket (fits all i believe) make offer - A/C compressor (pretty sure it fits all) - T25 compressor outlet pipe - $15 - Stainless Steel Braided Oil Line 3ft. - $20 - Vacuum Tank with check valve and lines - $5 - T25 heatshields - make offer - Stock fan with clutch - $10 - Stock Turbo oil lines Feed and Return (CA18) make offer - Oil Pressure Sender (fits all CA KA SR) - make offer - Engine Coolant Temp Sensor (for stock dash gauge) - make offer - Auto trans Kick down switch (came off KA) make offer - Random Hoses, Brackets, Bolts - gay ricer shift knob - free!! (pickup only) - pencil is not for sale. Link to comment
metalmonkey47 Posted October 24, 2010 Report Share Posted October 24, 2010 What tranny is the speedo cable for? Assuming L series. You know if it will fit a A series 5 speed? Link to comment
NCRmtrsprts510 Posted October 24, 2010 Author Report Share Posted October 24, 2010 What tranny is the speedo cable for? Assuming L series. You know if it will fit a A series 5 speed? yes it worked on the L series, i dont think there would be difference between the two regarding the speedo cable.. not 100% sure though lol Link to comment
metalmonkey47 Posted October 24, 2010 Report Share Posted October 24, 2010 yes it worked on the L series, i dont think there would be difference between the two regarding the speedo cable.. not 100% sure though lol Alright, in that case I'll check into it. If it fits, I'll take it Link to comment
NCRmtrsprts510 Posted October 26, 2010 Author Report Share Posted October 26, 2010 bump prices are all OR BEST OFFER!! Link to comment
NCRmtrsprts510 Posted October 31, 2010 Author Report Share Posted October 31, 2010 bumpity bump Link to comment
Mini-L320 Posted November 1, 2010 Report Share Posted November 1, 2010 Pm'd on the Turbo Oil Feed/Return Lines. Link to comment
NCRmtrsprts510 Posted November 8, 2010 Author Report Share Posted November 8, 2010 bump i need money so i can drive my datto! AND Prices Lowered!!!1 Link to comment
NCRmtrsprts510 Posted November 21, 2010 Author Report Share Posted November 21, 2010 bmup Link to comment
AZhitman Posted November 21, 2010 Report Share Posted November 21, 2010 Put all that CA / KA / SR stuff here: http://forums.nicoclub.com/engine-drivetrain-for-sale.html Those guys have CA / KA / SR-powered cars. ;) Link to comment
pondking Posted August 4, 2011 Report Share Posted August 4, 2011 got a box full of 510 parts came from a 1970.. local preferred - Gas tank (no filler neck) $40 - Radiator with hoses and cap $40 - Stock dash modified to fit auto meter gauges - no cracks! - $50 - coil - make offer - some resistor box thing - make offer - COMPLETE Throttle assembly including inside the cab - SOLD - speedometer cable (works with autometer gauges) - make offer - factory tire iron (i think) - make offer - hand brake assembly everything from the handle to the mount and cable leading to the crossmember - $30 - Hood prop assembly with spring - make offer - custom aluminum center part of dash (matches curves of stock dash) made to fit three 2-5/8" autometer gauges - make offer - Lug nuts - make offer I probably have some other parts laying around, if i find some more, i will add them to the list. please make reasonable offers and ALL prices are OBO! Also Got another box full of parts, ALL will fit CA18, Almost all parts came off of a CA18DET, some will fit both KA24 and SR20 . - T25 Garrett AR.48 / AR.49 Internal wastegate 8psi turbo - some play - $100 - T25 downpipe with o2 bung - 2 broken studs - make offer - CA18 Turbo manifold - if anyone even has a ca18 lol - Stock Fuel pressure regulator - fits all i believe - $20 - Power Steering Pump w/ bracket (fits all i believe) make offer - A/C compressor (pretty sure it fits all) - T25 compressor outlet pipe - $15 - Stainless Steel Braided Oil Line 3ft. - $20 - Vacuum Tank with check valve and lines - $5 - T25 heatshields - make offer - Stock fan with clutch - $10 - Stock Turbo oil lines Feed and Return (CA18) make offer - Oil Pressure Sender (fits all CA KA SR) - make offer - Engine Coolant Temp Sensor (for stock dash gauge) - make offer - Auto trans Kick down switch (came off KA) make offer - Random Hoses, Brackets, Bolts - gay ricer shift knob - free!! (pickup only) - pencil is not for sale. Have you sold the Gauges? Link to comment
BAOner Posted August 10, 2011 Report Share Posted August 10, 2011 30 bucks for the cluster trim Link to comment
