FoxyRoadster Posted October 15, 2010 Report Share Posted October 15, 2010 Ok seriously guys I'm looking for a set of the hayashi yayoi (most know them as the sakura rims) http://www.hayashiracing.com/yayoi/yayoi.html I know they are being reproduced but cant locate a US source for them, I really want a set for the roadster as I think they'd look good on one. Quote Link to comment
Radim Posted October 15, 2010 Report Share Posted October 15, 2010 I can import them for you but be prepared to shell out well over 1-3,000USD for them... If you are truly interested PM me i will search for a set overseas. Or i can order them straigh from Hayashi. Quote Link to comment
808DA6 Posted October 15, 2010 Report Share Posted October 15, 2010 They would look absolutely badass. Good luck finding a set. These, along with other CHOICE wheels, probably aren't going to be distributed on the US. -Brian Quote Link to comment
hang_510 Posted October 15, 2010 Report Share Posted October 15, 2010 I can import them for you but be prepared to shell out well over 1-3,000USD for them... :ph34r: how much are a set of cherry blossoms??? Quote Link to comment
Radim Posted October 15, 2010 Report Share Posted October 15, 2010 Those are Cherry Blossoms, (Yayoi, Sakuras ect.. :P) Quote Link to comment
FoxyRoadster Posted October 15, 2010 Author Report Share Posted October 15, 2010 I can import them for you but be prepared to shell out well over 1-3,000USD for them... If you are truly interested PM me i will search for a set overseas. Or i can order them straigh from Hayashi. Awesome I'll keep you in mind then and yeah I'm ready for it. Going to be a nice xmas gift for my roadster. :cool: Being 84,000 yen I was expecting 1,500-1600 shipped. edit: unfortunately they dont come in my cars lug patern. I might end up getting these, but honestly I like the hayashis way better. http://www.nlmotoring.com/Axis-Sakura-Wheels-15x8-Pink-p/axis-sak5804c25pnk.htm Quote Link to comment
schicksal Posted October 15, 2010 Report Share Posted October 15, 2010 Just to let you know in Japan they show the price per wheel. So the 84k yen is per wheel for a full set you would be spending around $4.5k US. 1 Quote Link to comment
Radim Posted October 16, 2010 Report Share Posted October 16, 2010 Yep, forgot to mention that, 1-3K is for a used set of mild wheels (13-14s 5.5-7" wide with mid offsets) wide with 0 to negative offset will run you more. Quote Link to comment
hang_510 Posted October 16, 2010 Report Share Posted October 16, 2010 So the 84k yen is per wheel, you would be spending ... $1,031 ea /todays exchange that 4 510's to me :( Quote Link to comment
FoxyRoadster Posted October 16, 2010 Author Report Share Posted October 16, 2010 Yep, forgot to mention that, 1-3K is for a used set of mild wheels (13-14s 5.5-7" wide with mid offsets) wide with 0 to negative offset will run you more. Yeah I kinda figured that on their site as very few wheel sellers show a price for all four. I'm not wanting major offset as my roadster would eat the tires on wide wheels. I'm just wanting the small offset, and will be buying used of course as my gf would kill me if I spent 4k on rims for a 400 dollar roadster. Though I'm kinda thinking of just getting some wheel adapters and taking my chances with the knock offs. Quote Link to comment
Radim Posted October 16, 2010 Report Share Posted October 16, 2010 What's the lug pattern on the Roadsters? I can help you get the wheels redrilled to fit but the lug holes will be oval, and you'd have to use mag lugs. Quote Link to comment
FoxyRoadster Posted October 16, 2010 Author Report Share Posted October 16, 2010 standard 4x114.3 datsun lug Quote Link to comment
Radim Posted October 16, 2010 Report Share Posted October 16, 2010 Oh, i'm pretty sure they make them in 4x114 then. Edit: Just checked.. they don't. :( Should be easy to redrill... unless you still want to run adapters. Quote Link to comment
FoxyRoadster Posted October 16, 2010 Author Report Share Posted October 16, 2010 Oh, i'm pretty sure they make them in 4x114 then. Edit: Just checked.. they don't. :( Should be easy to redrill... unless you still want to run adapters. I found axis doesn't make any rims in our sizes, it sucks I'd think they'd sell a lot too. I might run adapters, they aren't too bad if you check up on them and also place grease between the adapter and drum/rotor. Plenty of vw'ers run them with no issues doing that. Quote Link to comment
