primo74620 Posted October 3, 2010 Report Share Posted October 3, 2010 Where can I find a Diagram of the fusebox on a 74' 620. I need to check my taillights and marker lights. Quote Link to comment
primo74620 Posted October 3, 2010 Author Report Share Posted October 3, 2010 Here it is: Thanks ggzilla, what is that battery/alternator and ignition switch? what fuses work on those two? Which fuse would be for the marker lights? Quote Link to comment
ggzilla Posted October 4, 2010 Report Share Posted October 4, 2010 The battery has no fuse. The cover has the wiring shematic * Where it says battery/alternator indicates it feeds the top left and all the right fuses. Quote Link to comment
ggzilla Posted October 4, 2010 Report Share Posted October 4, 2010 The side marker lights are "Park" lights, the 10 amp fuse. Quote Link to comment
primo74620 Posted October 4, 2010 Author Report Share Posted October 4, 2010 The side marker lights are "Park" lights, the 10 amp fuse. Once again, thanks for the info. you have shared with me. Quote Link to comment
moparvwfreak Posted October 11, 2010 Report Share Posted October 11, 2010 that is unless you have a later model fuse box like i do. then the difference is the headlights are run through the ignition portion of the box and not through the battery side. Quote Link to comment
