frodo70444 Posted September 24, 2010 Report Share Posted September 24, 2010 lookin at this 210 sedan but the brake pedal has no pressure and when i push it to the floor the engine idles rough with a little fuel it levels out just fine all the fluid levels are fine where should i start? Quote Link to comment
metalmonkey47 Posted September 24, 2010 Report Share Posted September 24, 2010 Probably a vac leak at the brake booster. Check your vac line to the booster for cracks or ANY leaks. If none, you should start pricing them. Quote Link to comment
frodo70444 Posted September 24, 2010 Author Report Share Posted September 24, 2010 Probably a vac leak at the brake booster. Check your vac line to the booster for cracks or ANY leaks. If none, you should start pricing them. awesome thank u very much Quote Link to comment
Mini-L320 Posted September 25, 2010 Report Share Posted September 25, 2010 Maybe needs brakes bled Out? has the car been sitting for a long time? Check your hose from the Intake to the booster. Mine has a rough idle if I keep pressing the brake pedal quickly. and once I let go it stays idling at 800 all day. Check the rear Wheels to see if there is any brake fluid on the back of the wheels, probably a bad Wheel Cylinder. I had the same problem when i first got my 210 Quote Link to comment
frodo70444 Posted September 25, 2010 Author Report Share Posted September 25, 2010 Maybe needs brakes bled Out? has the car been sitting for a long time? Check your hose from the Intake to the booster. Mine has a rough idle if I keep pressing the brake pedal quickly. and once I let go it stays idling at 800 all day. Check the rear Wheels to see if there is any brake fluid on the back of the wheels, probably a bad Wheel Cylinder. I had the same problem when i first got my 210 all fluid level are fine full to top the pedal has no pressure an it idles rough when i push the pedal afte ri let it up and give it a shot of octane it level out thanks for ur time and effort nice to know pople accualy care Quote Link to comment
frodo70444 Posted September 25, 2010 Author Report Share Posted September 25, 2010 Maybe needs brakes bled Out? has the car been sitting for a long time? Check your hose from the Intake to the booster. Mine has a rough idle if I keep pressing the brake pedal quickly. and once I let go it stays idling at 800 all day. Check the rear Wheels to see if there is any brake fluid on the back of the wheels, probably a bad Wheel Cylinder. I had the same problem when i first got my 210 Quote Link to comment
