mirageshepard Posted September 5, 2010 Report Share Posted September 5, 2010 I'm currently in the middle of redoing my vacuum lines on my 86 nissan hardbody nap z2.4I (throttle body injection). Since I found out a couple days ago that before I got it this truck it has had atleast 1 engine (possibly 2) changes & it has seen atleast 3 shotty mechanics. I've got a vacuum diagram that I found on the net but it confuses me because right @ the throttle body are vaccum ports for hoses (in diagram) but I can only find 1 port on throttle body & its @ bottom on the rear left. I've so far got the diagram right from canister (cap top vacuum hose) to TVV then it splits off from there but still I don't see where all the vacuum hoses go to the throttle body....many thanks in advance! Quote Link to comment
datzenmike Posted September 5, 2010 Report Share Posted September 5, 2010 Yes, some diagrams are confusing. There is often a tee with several hoses but shown as separate connections. Try this one: Quote Link to comment
mirageshepard Posted September 6, 2010 Author Report Share Posted September 6, 2010 Yes, some diagrams are confusing. There is often a tee with several hoses but shown as separate connections. Try this one: I've done the best I could with it, do to things not being exact because of other people that have worked on this in the passed & things not where there suppose to be.....it runs steady but its weak. I just changed plugs & that didn't really do much but they were looking rough (build up on 1 side of plug & smutty or black). IF I remember right, you said something a while back about removing emissions vacuum being a bad idea (in not so exact words) so I'm trying to keep everything under the hood. It still doesn't have the pep that it did when it was runninig really well 1 day & wouldn't start the next. I'm getting NGK wires & some sort of washable air filter next week & if the work I've done with the vacuum lines & replacing routine stuff doesn't do the trick then I guess I just gota tough it out till I can get the cash for the KA. Oh yeah I tried to run codes from computer, even thats not acting right because when I wait for mode selection it doesn't select modes it just go's straight to giving me 23 24 23 24.....etc etc etc. Any help is appreciated. Quote Link to comment
mirageshepard Posted September 6, 2010 Author Report Share Posted September 6, 2010 Someone on another forum asked for pics so I thought it would be a good idea to show them here as well I hope I'm posting this correctly, I hope these pics are the right size & in order as the titles I've listed. Keep in mind that my TVV is a 3 port. metal tubes on side of intake Vacuum line from air cleaner to top port on TVV Y connection for top port on canister & EGR + BPT to middle port on TVV connections to EGR + BPT this is the vacuum port on the back left of the throttle body I hooked the vacuum hose coming from that port on the throttle body to the bottom port on the TVV because I didn't know where else to put it this is a little brass or copper looking vacuum tree that I just put a hose on 1 of the 2 ports & capped off the other port. (you can even see the top port on the TVV where the air cleaner vacuum hooks to) Quote Link to comment
datzenmike Posted September 6, 2010 Report Share Posted September 6, 2010 .... because when I wait for mode selection it doesn't select modes it just go's straight to giving me 23 24 23 24.....etc etc etc. Any help is appreciated. Warm engine. Tranny in neutral or auto in PARK Be sure mode is set to OFF. turn motor off. turn ignition on (not start) both mode lamps must stay ON turn mode selector to ON make sure 23 and 24 is displayed depress gas peddle and release only 24 should be displayed depress clutch and place in any gear let up clutch. auto shift into any gear depress clutch and shift back to neutral and auto into PARK Code 44 should be displayed .. everything OK if not record malfunctioning code(s) memory erase: turn mode to OFF 2 seconds later turn ignition OFF Fault codes erased Quote Link to comment
mirageshepard Posted September 6, 2010 Author Report Share Posted September 6, 2010 THANKS!..I was doing it by book.....book is so WRONG, everything went well & its showing 44......but its still weak, guess I gota deal with it being weak since everything is showing up good. Quote Link to comment
