J15 exhaust manifold
burrito213
  • Replies 2
The MGB manifold won't fit a 320. Might fit a 410 or a RHD vehicle, but not a LHD with a solid steering tube. In fact the J13 manifold from a 520 probably doesn't fit in a 320 either (larger diameter)- pretty much need to use the original E1 manifold (it bolts right up to the J-series). And yes, the E1 manifold is kind of weak. As far as gaskets the MGB one works fine in E1, J13, J15, J16 etc.
If you got a 520 or a forklift mani on that J15 and it actually fit, let me know, because I was going to have my E1 manifold welded up (it's cracked at the collector) to put on my J16 for my 320 because eyeball said the J13 manifold wouldn't clear the steering. But I could be wrong.
