oldschool90 Posted August 25, 2010 Report Share Posted August 25, 2010 Just wonderin if someone could tell me where all the electrical components are for the AC in my 81 720. Bought it off a neighbor and it looks like he jerry rigged it and messed everything up. Heres what Ive got: wire from wiper fuse to terminal closest to engine on switch in heater controls wire from center terminal on switch in heater controls to a ground near the battery tray (i think, too dark to double check right now) (the first two wires might be switched on the switch but idk) empty terminal on switch in heater controls wire from compressor to + side of battery Heres what the manual says: red w/ yellow wire from low pressure switch goes to terminal for option connector for heater, also goes to thermo switch red w/ blue wire from thermo switch goes to compressor switch, and ac warning light blue wire from compressor switch goes to heater option connector, ac relay, intermittent wiper amplifier,fuse block, heater relay, wiper motor, and washer motor red w/green wire goes tofan switch, ac lamp, and ac relay red w/ black goes to option connector, F.I.C.D. solenoid, and ac relay I know this manual covers multiple models and stuff, so can someone be so kind to tell me where everything is on my truck? Thanks! Quote Link to comment
izzo Posted August 25, 2010 Report Share Posted August 25, 2010 what manual do you have? Quote Link to comment
izzo Posted August 25, 2010 Report Share Posted August 25, 2010 nevermind that, i have a 81 720 wiring diagram pdf, its 4-5 pages long, should be exact to that year. get me your email address and ill send it. Quote Link to comment
oldschool90 Posted August 25, 2010 Author Report Share Posted August 25, 2010 The one I was looking at was Haynes, but I also have what looks like a service manual that I was going to look at tomorrow. Quote Link to comment
oldschool90 Posted August 25, 2010 Author Report Share Posted August 25, 2010 Thanks! Quote Link to comment
