Hooligans Posted December 27, 2007 Report Share Posted December 27, 2007 I am new to the Datsun scene and need some advice. I just got a FREE 1978 Datsun 510....(not the most sought after I know) with a L20B. What are some good mods for this motor? Any links or advice would be greatly appreciated. Quote Link to comment
datzenmike Posted December 27, 2007 Report Share Posted December 27, 2007 Find out if the solid rear axle has an H190 rear gear in it. If so the truck rear gears will fit and give you a 4.11, 4.375, 4.625 and even higher. This would allow you to 'get into it' sooner, RPM wise. Won't affect mileage around town much, but gives an added kick in the ass take off. A few hours work to do and you don't have to touch the motor. Motor modifications will dovetail nicely with this later on. Quote Link to comment
69FJWagon Posted December 27, 2007 Report Share Posted December 27, 2007 Find out if the solid rear axle has an H190 rear gear in it. If so the truck rear gears will fit and give you a 4.11, 4.375, 4.625 and even higher. This would allow you to 'get into it' sooner, RPM wise. Won't affect mileage around town much, but gives an added kick in the ass take off. A few hours work to do and you don't have to touch the motor. Motor modifications will dovetail nicely with this later on. I dont think thats true... I am almost possitive it has a h190 rear end but I think its just like an early 510 wagon h190 they have different amount of splines on the axels than the truck so the axels wont slip into the carrier. I think Fineline said that the trucks have a 29 spline axel and the 510 wagons have a 25 or 27... you can make it work but it takes some time and research. Quote Link to comment
datzenmike Posted December 27, 2007 Report Share Posted December 27, 2007 While the rears are out remove the pinion mate shaft from the differential case by removing the roll pin that holds it in. This will allow the two pinion mate gears and thrust washers to fall out which in turn will allow the two side gears, (with the wrong spline count) room to be removed. Replace with the 510 ones and re-assemble. The 510 axles will now be fitting onto their own 510 side gears. Quote Link to comment
