Grey_Matter Posted July 27, 2010 Report Share Posted July 27, 2010 is this correct for which is which? i know the the gap is wrong in the pic, but is the intake and exhaust correct? Quote Link to comment
datsunaholic Posted July 27, 2010 Report Share Posted July 27, 2010 Firing order and cylinder numbering is wrong. 1-3-4-2, viewed from the crank pulley end. But valves are E I I E E I I E, as noted. Quote Link to comment
nismo dr Posted July 27, 2010 Report Share Posted July 27, 2010 http://community.ratsun.net/topic/16539-l-series-valve-adjustment/ Quote Link to comment
Grey_Matter Posted July 28, 2010 Author Report Share Posted July 28, 2010 Firing order and cylinder numbering is wrong. 1-3-4-2, viewed from the crank pulley end. But valves are E I I E E I I E, as noted. yeah i knew the firing order was wrong, i was only concerned about which is intake and which is exhaust. i had an idea but just wanted to make sure i was right. http://community.rat...lve-adjustment/ this vid helped me, i tried using the search on here..but the search is worthless on here :) im glad i watched this cause i was definitely putting my feeler guage in the wrong spot, i was trying to gap it where the rocker arm hits the valve spring Quote Link to comment
hang_510 Posted July 28, 2010 Report Share Posted July 28, 2010 which is intake and which is exhaust. i had an idea but just wanted to make sure i was right. its obvious w/the cover off, just look @ the corresponding IN / EX mani spot. i double check it myself Quote Link to comment
nismo dr Posted July 28, 2010 Report Share Posted July 28, 2010 Good deal, its one thing to try and explain something, but it makes all the difference to just watch someone do it Quote Link to comment
