cobra269 Posted July 13, 2010 Report Share Posted July 13, 2010 Need speedo cog from an L series 720 with the 3.70 or 3.889 gear set. Also need the three plugs as pictured for a L series 5 speed tranny. I am sure I could get the plugs from the hardware store, but they are always closed when I get home, so if you have any you could spare please let me know, will give something for them. Thanks for any help... Link to comment
datzenmike Posted July 13, 2010 Report Share Posted July 13, 2010 Looks like the 18 tooth is the most common one for '80 2wd 5 speed. The number is 32702 E9818 or 32702 58S18. There were optional tires and rims and also a dual rear tire so it could be one tooth higher or lower. For a 19 tooth substitute a 19 in place of the 18 in the above part numbers. Link to comment
