mswit209 Posted July 10, 2010 Report Share Posted July 10, 2010 ok i have been staring at my car for too long. how in the hell do you remove the windows from the doors? i have a 72 4 door i also would like to know how to remove the rear quarter window behind the rear door window. Quote Link to comment
hobbes_the_cat Posted July 11, 2010 Report Share Posted July 11, 2010 should be in all the haynes and chilton manuals. get one if you don't have one. take inner door panel off, roll window most of the way down and you should be able to access the wire clips that hold the window to the arms. should just pull off with your fingers. then i think the window will slide out sideways. rear window quarters: remove rear window as described, then remove the bar between mobile window and stationary window, two screws on top of door under the weather stripping and one bolt low on the inside of the door previously under the door panel. then it slides out probably have to work it out slow cause the rubber will be real tight. ;) Quote Link to comment
hang_510 Posted July 11, 2010 Report Share Posted July 11, 2010 ... to access the wire clips that hold the window to the arms. should just pull off with your fingers. then i think the window will slide out sideways. the clip is behind the rail(not visible) you have to pull it off that pin and slide it out of the rail before it will come up, kinda sideways at first. the R fixed window: unless your painting or have the replacement seal, be careful!!! Quote Link to comment
mswit209 Posted July 11, 2010 Author Report Share Posted July 11, 2010 well got all windows out sucessfully. the little quarter windows i sprayed wd-40 down the top and it helped break the seal of the ruber so they are all intact thank godness :rolleyes: Quote Link to comment
