521Lvr Posted December 18, 2007 Report Share Posted December 18, 2007 ok.. so I got my EI matchbox dizzy today. thanks yello620 so.. How do I wire it? I am using an msd blaster too thanks guys tc Quote Link to comment
banzai510(hainz) Posted December 18, 2007 Report Share Posted December 18, 2007 I guess I didnt post this enough make sure when you install it ,the rotor points in the correct direction. Hopefully yelo620 sent the whole distributor with timming plate and mount.If in dought set to #1 TDC and see where your off if it doesnt point to #1 just put 2 male ends on the + post of the coil and use the stock 12v ON wire hookes up to the coil(remove the ballast) then then make a red wire(B) with a female blade connector to plug in at the coil C make this a blk wire with a female end on there and just plug in the the neg side coil thats it ignor the tack sensor wire in drawg below good luck Quote Link to comment
fiveNdime Posted December 19, 2007 Report Share Posted December 19, 2007 This is how mines wired up and I have had no issues. Works great I actually wired the whole truck without a diagram and never had a problem, I just hate doing it. I would try to stay away from splicing the positive to the coil and positive to the ignition box together. Quote Link to comment
521Lvr Posted December 19, 2007 Author Report Share Posted December 19, 2007 got it running awesome today. I just had c & b mixed up b4 I posted. thanks Quote Link to comment
