dimedude Posted June 22, 2010 Report Share Posted June 22, 2010 found a set of wheels i was thinking about buying but no sure if they will fit there 15x7 with a +25 offset my 510 is lowered 1 inch Quote Link to comment
djaztek12 Posted June 23, 2010 Report Share Posted June 23, 2010 got pictures they should fit fine :P Quote Link to comment
Yakuza Posted June 23, 2010 Report Share Posted June 23, 2010 +25 should be ok...maybe a small spacer depending if you're using zx struts...but will work for sure.GL Quote Link to comment
dennis Posted June 27, 2010 Report Share Posted June 27, 2010 found a set of wheels i was thinking about buying but no sure if they will fit there 15x7 with a +25 offset my 510 is lowered 1 inch You should be fine, just make sure you watch your tire size. I wouldn't run anything more than 195/50's up front. I have less than 1/2" clearance from tire to strut tube with 15 x 7 +15 offset. Quote Link to comment
jhughes26 Posted July 6, 2010 Report Share Posted July 6, 2010 looking at a 15x8" set of RB rotas, they say they have 35mm offset, http://www.racinglab.com/rota-rb-15x8-4100-35.html my rear is flared so I'm not worried about that, you guys think it will clear the front? my front is stock except for some antiroll bars and not lowered, I could just go with the 7" but I'm wanting a 8... Quote Link to comment
greengoon Posted July 7, 2010 Report Share Posted July 7, 2010 15 x 7 +25s should barely fit stock struts. Its pretty tight though. I just put 15x7 +20s on my shortened stock struts and have about 1/4" to the strut. 15 x 8 +35s will need at least a 1" spacer to clear the strut. You should be more in the +10 range and then the wheel will still stick out beyond stock front fenders. Maybe try 8s in the back and 7s in the front. Rotas have a lot of sizes and offsets available. Try JLBMotorsports.com 1010tires.com has a good wheel offset calculator. Quote Link to comment
INDY510 Posted July 7, 2010 Report Share Posted July 7, 2010 looking at a 15x8" set of RB rotas, they say they have 35mm offset, http://www.racinglab.com/rota-rb-15x8-4100-35.html my rear is flared so I'm not worried about that, you guys think it will clear the front? my front is stock except for some antiroll bars and not lowered, I could just go with the 7" but I'm wanting a 8... Uh....... Dude...... The link you posted is a 4x100 bolt pattern............. and no....... a 15x8 +35 will not fit on stock struts The only offset they offer in your bolt pattern is 15x8 +0,,,, and they will probably fit,,, but you will need flares Quote Link to comment
jhughes26 Posted July 7, 2010 Report Share Posted July 7, 2010 thanks guys, ended up going for the 15x7, seems like thats the best choice, maybe 8s in the back later, when i have enough power to justify it... yeah i ended up realizing i'd need the 114s...that would have been bad... Quote Link to comment
memo Posted July 15, 2010 Report Share Posted July 15, 2010 thanks guys, ended up going for the 15x7, seems like thats the best choice, maybe 8s in the back later, when i have enough power to justify it... yeah i ended up realizing i'd need the 114s...that would have been bad... i have 16x8 with +24 off set and they fit like a charm. Quote Link to comment
