nachito61977 Posted June 17, 2010 Report Share Posted June 17, 2010 I removed my carb and dont remember how to rebuild it so I want to know what other carb fitts in the stock intake for a 66 520? Quote Link to comment
datzenmike Posted June 17, 2010 Report Share Posted June 17, 2010 A good rebuild kit will have the info on rebuilding it and with pictures. They usually have gauges to set the float drop as well. You can do it! You just need a large kitchen table covered with newspapers, carb cleaner and an old toothbrush and a few Q-tips. A digital camera helps if you haven't taken it apart yet. Quote Link to comment
nachito61977 Posted June 17, 2010 Author Report Share Posted June 17, 2010 A good rebuild kit will have the info on rebuilding it and with pictures. They usually have gauges to set the float drop as well. You can do it! You just need a large kitchen table covered with newspapers, carb cleaner and an old toothbrush and a few Q-tips. A digital camera helps if you haven't taken it apart yet. to late already removed and dipped in acid ran out of daylight so called it quits. ill take some pix maybe someone can ID it Quote Link to comment
