hardhead320 Posted June 16, 2010 Report Share Posted June 16, 2010 Recently installed a new J-series motor with new head gasket torqued to about 50lbs started motor and ran motor and there did not seem to be any leaks, then repulled motor and painted it. 5 months later reinstalled motor and started it, now I have a leak between the block and the head so I re torqued it to 50lbs and that seemed to stop the leak, but I don't know the correct torque specs for the head studs anybody got any idea on what the spec is? Quote Link to comment
datzenmike Posted June 16, 2010 Report Share Posted June 16, 2010 J13/J15 is 36-43 pounds. 50 isn't that bad. Did you check the head for warp-age. If not flat it could fail. They must be torqued in this sequence below. Start by torquing in sequence to 20 then in sequence to finished 45. -----8--3--5--11 14--7--2--4--10--15 RAD --12--6--1--9--13 Quote Link to comment
hardhead320 Posted June 16, 2010 Author Report Share Posted June 16, 2010 J13/J15 is 36-43 pounds. 50 isn't that bad. Did you check the head for warp-age. If not flat it could fail. They must be torqued in this sequence below. Start by torquing in sequence to 20 then in sequence to finished 45. -----8--3--5--11 14--7--2--4--10--15 RAD --12--6--1--9--13 Yes had the head machined should I re torque cold or hot? Quote Link to comment
datzenmike Posted June 16, 2010 Report Share Posted June 16, 2010 Always cold. Check the torque at every tune up. Quote Link to comment
hardhead320 Posted June 16, 2010 Author Report Share Posted June 16, 2010 ok thanks for all the info i will do it tomorrow when I get home from work. A little panic set in when I first saw the coolant!!!!!! Quote Link to comment
