kondog Posted June 15, 2010 Report Share Posted June 15, 2010 I decided to lower the 521, so I took to it my mechanic, he ordered 3 inch blocks and 2 hours later I noticed my truck sat an inch lower on the left. after messing with the torsion bar he told me the leaf spring is probably bad, and I do remember seeing her sit lower on the left prior to the drop. which brings me here.... i'm having a hell of a time finding a replacement spring for the 521. Is there a compatible year nissan part number I can order from nissan. thanks for any help AND yes I did do a search Quote Link to comment
datzenmike Posted June 15, 2010 Report Share Posted June 15, 2010 All trucks through the 720 are compatible (same length) if you buy both so they match. 720 4X4 are slightly stiffer and flatter. Quote Link to comment
kondog Posted June 15, 2010 Author Report Share Posted June 15, 2010 thank you. Quote Link to comment
