Ozomatli Posted June 10, 2010 Report Share Posted June 10, 2010 Hello Im looking tor a "drive shaft", and a "plach disc" for a B210 5-speed transmission (dogleg pattern) I want to put it into my Datsun B210, instead of its 4-speed trany. any help would be great! Link to comment
datzenmike Posted June 11, 2010 Report Share Posted June 11, 2010 Are these internal parts for the dogleg? Link to comment
Ozomatli Posted June 11, 2010 Author Report Share Posted June 11, 2010 [/media] Are these internal parts for the dogleg? Hello, I believe they are internal parts the "plach disc" or at least is what i believe is called goes where the blue arrow points it would be situated between the transmission and the engine , and the drive shaft goes were the yellow arrow points to, the drive shaft end that i need in particular kind of looks like the part in the lower right , (except it has teeth), that connect to the transmission. Uploaded with ImageShack.us Link to comment
datzenmike Posted June 11, 2010 Report Share Posted June 11, 2010 The 'platch disc' would be the 'engine plate' the thin plate sandwiched between the transmission and the engine. Got it now. The drive shaft is the drive shaft. Link to comment
izzo Posted June 11, 2010 Report Share Posted June 11, 2010 whiskey tango foxtrot... The plate that goes between the engine and transmission is called an inspection plate usually. The drive shaft is a no brainer, pretty sure mike was talking about the "plach disc" I dont have either parts, good luck with it tho. Link to comment
Ozomatli Posted June 11, 2010 Author Report Share Posted June 11, 2010 whiskey tango foxtrot... The plate that goes between the engine and transmission is called an inspection plate usually. The drive shaft is a no brainer, pretty sure mike was talking about the "plach disc" I dont have either parts, good luck with it tho. well thanks anyways! Link to comment
