boxrocket Posted May 30, 2010 Report Share Posted May 30, 2010 I'm starting to piece together a VG swap and had a few questions on compatibility. Will an 1986 300zx 5 speed trans work with an 03 VG33? And also if that is possible what do I need to look at for a clutch package and a compatible lightweight flywheel? Quote Link to comment
Jesse C. Posted June 1, 2010 Report Share Posted June 1, 2010 Externally, you can pretty much treat a VG33 the same as a VG30. The trans will work on either one. Quote Link to comment
