heirfaus Posted May 24, 2010 Report Share Posted May 24, 2010 Hey guys, any Mac pro's out there? I'm trying to install Megatune on my macbook and I don't understand Terminal. I grew up using DOS. I keep getting an error even when following the instructions: DEBUG: Rebuilding the darwinports base system if needed. Synchronizing from rsync://rsync.darwinports.org/dpupdate/dports @ERROR: Unknown module 'dpupdate' rsync error: error starting client-server protocol (code 5) at /SourceCache/rsync/rsync-35.2/rsync/main.c(1398) [receiver=2.6.9] DEBUG: Couldn't sync dports tree: sync failed doing rsync while executing "darwinports::selfupdate [array get global_options]" Error: /opt/local/bin/port: selfupdate failed: Couldn't sync dports tree: sync failed doing rsync What does this mean? Link to original instructions: http://www.msextra.com/forums/viewtopic.php?f=106&t=23434 Quote Link to comment
MikeRL411 Posted May 24, 2010 Report Share Posted May 24, 2010 Is this what Apple owners refer to when they brag about their user friendly interface? Quote Link to comment
heirfaus Posted May 24, 2010 Author Report Share Posted May 24, 2010 Is this what Apple owners refer to when they brag about their user friendly interface? Well, being a devoted PC person all my life, I will say EVERYTHING on the Mac is easier and more user friendly except when you get into the stuff where you have to mess around in terminal to get something to work. You have to remember that Megatunix is part of the Megatune world which is all grass roots collaboration. No big companies to make it nice and easy functioning :( Quote Link to comment
MikeRL411 Posted May 25, 2010 Report Share Posted May 25, 2010 Sounds like Megatune is like UNIX. Re Windows and microsoft in general, don't waste your money on initial release, wait until the second or third service pack. It may be usable by then. Quote Link to comment
baseten Posted May 27, 2010 Report Share Posted May 27, 2010 Those instructions are from 2007, and likely specific to an older version of OSX than what you might be running now. i don't muck about under the hood too much with OSX, but in the past when i did this sort of thing i had to install the OSX developer tools. i think you can download the package from apple, or they should be on your OSX dvd or on a 2nd dvd that came with OSX. Darwinports is/was a package management system that allowed unix-style software to be more easily installed. You might need to check that out, as it isn't self-updating. Also, do a quick google search on basic unix commands. it'll help you get around using the command prompt. Quote Link to comment
