sssr20det510 Posted May 19, 2010 Report Share Posted May 19, 2010 Ok I have a z dash in my 510 and the center gauges don't bolt in? They slid in the 3 holes is there a bracket I'm missing or what? Quote Link to comment
Skib Posted May 19, 2010 Report Share Posted May 19, 2010 IIRC its the same (should be) but the 240 dash its got an L shape bracket that goes on the gauge and then bolts to the frame Quote Link to comment
sssr20det510 Posted May 19, 2010 Author Report Share Posted May 19, 2010 Hmm I must be missing it, there is a bracket looking thing on the back of each gauge but I don't see anything that comes off it to bolt to the frame Quote Link to comment
Skib Posted May 19, 2010 Report Share Posted May 19, 2010 Hmm I must be missing it, there is a bracket looking thing on the back of each gauge but I don't see anything that comes off it to bolt to the frame Ill take a look at my Z Quote Link to comment
qwik510 Posted May 19, 2010 Report Share Posted May 19, 2010 Ill take a look at my Z IIRC, Each gauge should have a bracket on it with threaded studs sticking out. Those studs go into a bracket in the back of the dash and wingnuts hold the gauges in. Quote Link to comment
nullbound Posted May 20, 2010 Report Share Posted May 20, 2010 IIRC, Each gauge should have a bracket on it with threaded studs sticking out. Those studs go into a bracket in the back of the dash and wingnuts hold the gauges in. No wingnuts on a 280... The panel that holds the a/c controls needs to drop down. The bracket that holds each gauge is held in by a small phillips head screw at the bottom of the gauge that is visible once you drop the a/c panel. I use a short screwdriver to take out those screws. Then you can pop the gauges out. Quote Link to comment
sssr20det510 Posted May 20, 2010 Author Report Share Posted May 20, 2010 no i need them to stay in i have no heater controls or ac stuff from the z Quote Link to comment
junk yard z 77 Posted May 20, 2010 Report Share Posted May 20, 2010 that black bar is the part that the "brace" from the dash itself latches onto. each pod has a brace that straps from the top of the inner dash to the bottom with a small phillips screw .. when you take the middle vent with the map light section off you can access each of the screws to the particular guage. Quote Link to comment
sssr20det510 Posted May 20, 2010 Author Report Share Posted May 20, 2010 that black bar is the part that the "brace" from the dash itself latches onto. each pod has a brace that straps from the top of the inner dash to the bottom with a small phillips screw .. when you take the middle vent with the map light section off you can access each of the screws to the particular guage. I must be missing that then ??? Quote Link to comment
Skib Posted May 20, 2010 Report Share Posted May 20, 2010 Im goin out to snap some pics of mt Z's gauge mounts man, Ill have some pics a little later when I can use another comp (cant uploads pics from this one for some reason) Quote Link to comment
nullbound Posted May 21, 2010 Report Share Posted May 21, 2010 Look at these pics from the back side of a 280 dash (not my pics): Quote Link to comment
sssr20det510 Posted May 21, 2010 Author Report Share Posted May 21, 2010 Ok I need those brackets then megan never gave them to me when I got my dash Quote Link to comment
Nismopunch Posted May 21, 2010 Report Share Posted May 21, 2010 pretty cool swap, post some pictures of your interior when you finish!! Quote Link to comment
sssr20det510 Posted May 21, 2010 Author Report Share Posted May 21, 2010 pretty cool swap, post some pictures of your interior when you finish!! look at my build thread Quote Link to comment
gmac708 Posted May 22, 2010 Report Share Posted May 22, 2010 pix of center gauges including brackets 1970 240Z hope this helps Quote Link to comment
