620 brake problem
Str8_69
My 77 620 has had mushy brakes since I got it. I've replaced front drums and shoes, adjusted front and rear, and flushed the entire system and bled, all new fluid throughout. When I pump the pedal when the truck is not running, I get pretty good pedal, but when I run the truck, pedal gets mushy again and needs pumped before rolling up to every stop. The master seems ok, no leaks, or air bubbles, no leaks anywhere else either. I'm wondering if the booster could be the problem? I've been working on old cars for years, but have never had a booster go bad on me, so I don't know the symptoms. Should I try a new master first? Any help appreciated...
  • Replies 4
