195sRFast Posted May 7, 2010 Report Share Posted May 7, 2010 Does anyone know any way to change the oil pan gasket without pulling the engine? I was wondering if I could remove the frame member underneath? I have never seen it done so if you know how to do it, let me know. Quote Link to comment
datto510 Posted May 7, 2010 Report Share Posted May 7, 2010 With all of the work involved in just lifting the engine, you might as well pull the engine and di it right. You can replace the rear main seal while it is out too. Quote Link to comment
Pacific coast Datsun Posted May 7, 2010 Report Share Posted May 7, 2010 Simply drop the crossmember under the pan. That "should" allow the pan to drop down enough to install the new gasket. Quote Link to comment
sdsurf Posted May 7, 2010 Report Share Posted May 7, 2010 I changed mine without removing the engine or undoing the mounts. It was a pain but you can do it. Drop the pan as much as you can and slide it around under the crank. Quote Link to comment
