Dime Dave Posted April 30, 2010 Report Share Posted April 30, 2010 FutoFab, in an effort to continually improve its products announces a rod end boot up-grade for its Adjustable LCA’s. Inner Rod End w/Boot: Website link w/more details: FutoFab Rod End Boots To protect the LCA inner rod end from dirt and debris FutoFab offers Rod End Boots. These boots are perfectly designed to seal out dirt and moisture that will shorten rod end life. They can be installed on our LCA’s for an additional cost of $15/pair. The boots are sized to fit ½” thru ¾” rod ends, both male and female and work best with high mis-alignment spacers but will work with other spacer types. They can be used for most any rod end application that is mounted between spacers. Individual boots can be purchased loose for $7.50/each plus S&H. Quote Link to comment
