Ukrarex Posted April 29, 2010 Report Share Posted April 29, 2010 I recently bought a 79 620 kc, and the ride quality i just to saggy and soft for my taste, the previous owner changed the shocks not long ago but it still bounces around and leans in turns. I was thinking of getting the addco sway bars front and rear, and upgrading the rear leaf suspension. The rear is siting on a drop block, i would like to keep the drop but if its hindering the ride quality i will take it away. I was also looking trough summit racing and thinking about getting a set of afco racing springs with higher spring rate, would that be something that would fit with out any modification to the chassy? (http://www.summitracing.com/parts/AFC-20228LW/) Any suggestions would be much appreciated Quote Link to comment
datsunaholic Posted April 29, 2010 Report Share Posted April 29, 2010 I doubt the block alone is the problem. Likely they also yanked out most of the leaves. Most KCs have 5 leaves plus the overload. You can always replace the springs with unmolested ones, I'm sure someone wants those mush springs, but it's going to raise the rear back up a bit. Quote Link to comment
Ukrarex Posted April 29, 2010 Author Report Share Posted April 29, 2010 Uh yeah that explains alot, it has only 2 leaves. I havent dealt to much with leave spring suspensions but sense replacement parts for the 620 are rare , are there any after market leaf springs that would fit. Cause i would like to just replace them with a new parts so i dont have to worry about them for a while. Quote Link to comment
Farmer Joe Posted May 15, 2010 Report Share Posted May 15, 2010 one thing you might be able to do is get a set of springs from a 4x4 720. theyll bolt right in and dont have the big arch that a 2wd spring would have. theyre more flat. i bet you could get away with putting the block back on too. the 4x4 leafs will probably be at the same arch as the 2 you have on the truck, but youll have more leafs to hold up the load. Quote Link to comment
Ukrarex Posted May 15, 2010 Author Report Share Posted May 15, 2010 thanks that sounds like exactly what i need. Quote Link to comment
