nukeday Posted April 28, 2010 Report Share Posted April 28, 2010 I'm curious what you guys have done for vapor barriers in your doors/rear panels/kick panels? I've been considering a couple of things, if anyone has any experience please share it... 1. Double sided tape and sheet visquene 2. Home window 'shrink' kits 3. Press-n-stik Saran wrap Suggestions? Does anyone even put these back in? Quote Link to comment
MicroMachinery Posted April 28, 2010 Report Share Posted April 28, 2010 I put them back in unless they're too brittle and crack. I'd go for the visquene, but I'd probably use 3M adhesive, though. Double sided tape will eventually lose it's adhesion. Quote Link to comment
hang_510 Posted April 28, 2010 Report Share Posted April 28, 2010 Does anyone even put these back in? i havent even removed the original :rofl: i cant recall what the stuff is called, but its a sticky sheet rubber (made by Coleflex) that is perfect for this application. very similiar to what ever was used stock. stays pliable for years. i use it for those annoying rattles :) Quote Link to comment
