BlackWidow Posted April 19, 2010 Report Share Posted April 19, 2010 Hello all I am trying to figure out if the Datsun 510 spindles are forged or cast. I need to do some welding on them and i do see there is weld from the factory so i am under the belief that they are forged. I read somewhere that some people have cut the strut tube off the spindles and have had a machine shop remove the left over strut tube and weld to weld in different strut tubes. Anyway if anyone can help i would appreciate it. Thanks Mike G Quote Link to comment
SublimeDatsun610 Posted April 19, 2010 Report Share Posted April 19, 2010 i would believe forged. cast would not be strong enough. Quote Link to comment
sssr20det510 Posted April 19, 2010 Report Share Posted April 19, 2010 What are you trying to do Quote Link to comment
BlackWidow Posted April 19, 2010 Author Report Share Posted April 19, 2010 I have replaced my stock struts with 280zx struts so i have my stock struts and spindles sitting by idle. Well i am a big dwarf car fan and those cars use a modified toyota spindle. the toyota spindles and hubs a 4x4.5 just like the stock 510. I want to build a set of dirt track spindles for a dwarf car using the 510 spindles i have cut the strut tube off and used a hole to open the bottom of the spindle to 1 3/4. I plan on sliding a 1 3/4 .250 wall tube through the whole and weld out both sides. in the image you can see that the tube will slide in perfectly and give me a nice tight fit. i need to weld both side of the tube out to the stock spindle. I will be able to use the hubs and disc brake setup on my dwarf car and not have to hunt down toyota parts. Quote Link to comment
sssr20det510 Posted April 19, 2010 Report Share Posted April 19, 2010 You should not have a problem welding to them Quote Link to comment
BlackWidow Posted April 19, 2010 Author Report Share Posted April 19, 2010 Thank you Mike G Quote Link to comment
