datsundan Posted April 10, 2010 Report Share Posted April 10, 2010 i just picked up some rear wheel bearing seals for my dime from star auto and they are too small. does anyone know where i can find ones that are the right size. do i have some different size from a different car cause i have disc's in the rear (got the car with them- 200sx discs)? Quote Link to comment
HRH Posted April 10, 2010 Report Share Posted April 10, 2010 i just picked up some rear wheel bearing seals for my dime from star auto and they are too small. does anyone know where i can find ones that are the right size. do i have some different size from a different car cause i have disc's in the rear (got the car with them- 200sx discs)? 200sx discs shouldn't matter on the wheel seal size. It simply floats on the hub. Unless someone switched hubs. Either way, the correct seal should be 550230, which are available at your local NAPA parts house! Spokane warehouse has 2 in stock, but I didn't look at your location. Make sure you verify you have the rear trailing arm/hub assembly from a 510 and that someone hasn't swapped in something else. Quote Link to comment
datsundan Posted April 10, 2010 Author Report Share Posted April 10, 2010 200sx discs shouldn't matter on the wheel seal size. It simply floats on the hub. Unless someone switched hubs. Either way, the correct seal should be 550230, which are available at your local NAPA parts house! Spokane warehouse has 2 in stock, but I didn't look at your location. Make sure you verify you have the rear trailing arm/hub assembly from a 510 and that someone hasn't swapped in something else. what are the factory dimensions/ sizes for the stock rear hubs? im not sure if they are stock or not. also stasr told me it has two differnt size wheel bearings( an inner and an outer) but when i pulled the bearings the are both the same size about 60mm o.d. and a 30mm i.d. Quote Link to comment
datsundan Posted April 12, 2010 Author Report Share Posted April 12, 2010 I just stopped my napa to check out the seals from them and they are the same size as the ones I already bought. What options does a 510 have as far as rear trailing arm/hub assemblies from other cars? Quote Link to comment
HRH Posted April 12, 2010 Report Share Posted April 12, 2010 Sorry for the late reply. They may be 280zx arms, possibly S13, pretty much anything Nissan that's older can be retrofitted onto a 510. If your control arms don't look like this, they're off something else: Quote Link to comment
datsundan Posted April 12, 2010 Author Report Share Posted April 12, 2010 Thanks for the help. I dumabssed it and didn't hammer the inner bearing in enough :P. Got em to fit right in. Quote Link to comment
