datsoon'73 Posted April 1, 2010 Report Share Posted April 1, 2010 I need a little help to diagnose a electrical problem I'm having with my '73 620. I went to start it not too long ago started turning over like a champ then just stopped. I had the battery checked just to make sure it was good and, it is. I was wondering if it may be what looks like a relay mounted right next to the battery. Looks to have been replaced before. I almost forgot no head lights either. Any help would be greatly appreciated. Quote Link to comment
moparvwfreak Posted April 1, 2010 Report Share Posted April 1, 2010 check your grounds, then fuseable links. might have a bad one and its not sending juice to the fusebox. or anywhere else.. Quote Link to comment
ariascarlos1990 Posted April 1, 2010 Report Share Posted April 1, 2010 Have you checked your fuses? 1 Quote Link to comment
datsoon'73 Posted April 2, 2010 Author Report Share Posted April 2, 2010 Well, I guess I got it taken care of. After having the battery checked put it back in, broke positive terminal clamp putting it back on. So got a new clamp started to put it back on when the stripped strands broke off. I guess there was no real contact going on in the clamp, put it all back together, pretty much fired right up. Thought there was a lot more going on than that, so thanks for the input guys. I guess next time a little looking is in order. Like I said before thanks! Quote Link to comment
ppeters914 Posted April 3, 2010 Report Share Posted April 3, 2010 Glad it was simple, but it's a good reminder to always check the simple shit first, which means grounds and connections when you're talking electricity. Quote Link to comment
