Guest kamakazi620 Posted March 23, 2010 Report Share Posted March 23, 2010 I've seen A series engines and J series engines Whtas the Diferences???? can an A series trans bolt to a J series??? Quote Link to comment
ppeters914 Posted March 23, 2010 Report Share Posted March 23, 2010 ...and how much searching did you do before posting that question? Survey says....NONE! I get to be rude 'n' cranky when I see "gimme-gimme-I'm-too-lazy-to-search" questions. J: early pushrod motor. A: later OHC motor. I know folks have bolted L-motor trans to J motors, but you have to have the engine adapter, and the right mix of clutch, pressure plate, TO brg, etc. Dunno if A-motor trans will. Experts? Quote Link to comment
datsunaholic Posted March 23, 2010 Report Share Posted March 23, 2010 1) Differences? Lots. They're not related in any way. The only commonality is they are both pushrod engines. 2) No. Totally different rear pattern. Pete, the A-series isn't OHC. It's OHV. The L is the true OHC one, plus the U20 (which is a bastard R-series pushrod block with a OHC head) Quote Link to comment
ppeters914 Posted March 23, 2010 Report Share Posted March 23, 2010 1) Differences? Lots. They're not related in any way. The only commonality is they are both pushrod engines. 2) No. Totally different rear pattern. Pete, the A-series isn't OHC. It's OHV. The L is the true OHC one, plus the U20 (which is a bastard R-series pushrod block with a OHC head) Thanks, Doug. I was thinking OHV and typed OHC. Appreciate the correction. :thumbup: Quote Link to comment
