slow521 Posted November 25, 2007 Report Share Posted November 25, 2007 well here is a quick list of the stuff in my car. the car runs good the motor does not smoke or make strange nioses so i dont know what else it can be. its got a z20e block,the head is an L-series u-67,i instaled a sciracco radiator in it with help a bit but it still gets hot about 210 Quote Link to comment
datzenmike Posted November 25, 2007 Report Share Posted November 25, 2007 Over heating can be caused by all of the below: L head gasket on a Z series block... not all the holes are a match. thermostat: They are cheap, don't waste time and bother checking in hot water, just replace with a new one. fuel mixture too lean. retarded timing, ignition or cam. Poor water circulation: water level low a soft bottom hose will collapse when revved up. rad is filled with debris or corrosion inside. block or head is plugged with corrosion deposits. belt is slipping or loose. water pump is broken inside (unlikely) poor air circulation: clutch fan has failed and is not turning properly no fan shroud rad cooling fins are plugged with dirt, leaves, or bent. Quote Link to comment
