joe84 Posted March 18, 2010 Report Share Posted March 18, 2010 i know its been talked about before but, how hard is putting a sr20det in a 84 720 any info please,and what a is the cheapest why to put rear disc brake . Quote Link to comment
Pacific coast Datsun Posted March 18, 2010 Report Share Posted March 18, 2010 If $$$ is an issue ["what is the cheapest way"] keep it stock & drive it. Most swaps dont get done, $$$ runs out & you lose motivation. Quote Link to comment
joe84 Posted March 18, 2010 Author Report Share Posted March 18, 2010 o im going to do it ,dont care if it costs 5g .damn it i want a turbo motor,no what i mean on cheap was there a truck of another year that would bolt on or so.parts is no issue i work at a car parts store Quote Link to comment
izzo Posted March 18, 2010 Report Share Posted March 18, 2010 lol this question has been ran over about a half dozen times Find a 4x4 hardbody pickup and yank the motor out of it, along with wire harness and ecu. bolt it up to your 720 trans, hook up the 4 wires (check out the howto section for "How to wire a SR/KA to anything" thread). You will have to use different motor mounts i think? anyways, do that and your on the road. i would go with KA, a lot cheaper than SR from what i hear... good luck Quote Link to comment
joe84 Posted March 18, 2010 Author Report Share Posted March 18, 2010 lol this question has been ran over about a half dozen times Find a 4x4 hardbody pickup and yank the motor out of it, along with wire harness and ecu. bolt it up to your 720 trans, hook up the 4 wires (check out the howto section for "How to wire a SR/KA to anything" thread). You will have to use different motor mounts i think? anyways, do that and your on the road. i would go with KA, a lot cheaper than SR from what i hear... good luck the thing is im paying a shop to drop it in, so it will be FI, might as well turbo Quote Link to comment
izzo Posted March 18, 2010 Report Share Posted March 18, 2010 the thing is im paying a shop to drop it in, so it will be FI, might as well turbo the thing is, kade is fuel injected... thats why i said grab the wire harness and ECU.. its only 4 wires to get it running. You will need a bigger fuel pump also now that im thinking about it. I think with SR you will have to custom make an oil pan, and sr is more expensive. KAde out of a 4x4 will have the right pan to clear your steering linkage and shit in the 720. i could be wrong about the SR, someone who knows SR should pipe up lol... Quote Link to comment
joe84 Posted March 18, 2010 Author Report Share Posted March 18, 2010 the thing is, kade is fuel injected... thats why i said grab the wire harness and ECU.. its only 4 wires to get it running. You will need a bigger fuel pump also now that im thinking about it. I think with SR you will have to custom make an oil pan, and sr is more expensive. KAde out of a 4x4 will have the right pan to clear your steering linkage and shit in the 720. i could be wrong about the SR, someone who knows SR should pipe up lol... about what year for the motor to work and i can always turbo it ,do you know on the disk brakes for the rear out of what truck would bolt on Quote Link to comment
izzo Posted March 18, 2010 Report Share Posted March 18, 2010 about what year for the motor to work and i can always turbo it ,do you know on the disk brakes for the rear out of what truck would bolt on any 90s hardbody/d21, not sure what year the fuel injection started, i think the first few years were throttle body. And not sure about the rear end. Quote Link to comment
