hulk210 Posted March 16, 2010 Report Share Posted March 16, 2010 so i picked up a set of old american racing vector wheels, 14x7 with what i believe to be 0 offset, and i paired them up with the 280zx struts i picked up last week. i was looking to see if i had brake clearance before i mount the struts. turns out im going to be rubbing. what wheel size/dimension should i be looking at in order to clear those 280zx brakes? Quote Link to comment
MicroMachinery Posted March 16, 2010 Report Share Posted March 16, 2010 280zx's had 14" wheels from the factory. Is the rubbing issue minor enough that you could clearance the calipers with a small amount of grinding? Quote Link to comment
hulk210 Posted March 16, 2010 Author Report Share Posted March 16, 2010 280zx's had 14" wheels from the factory. Is the rubbing issue slight enough that you could clear the calipers with minor grinding? tell you the truth i didnt even think of that. i figured 0 offset should be fine when i purchased them. im sure i probably could but i could always just go with a different wheel too. Quote Link to comment
MicroMachinery Posted March 16, 2010 Report Share Posted March 16, 2010 I would try that before I went out and bought a new set of wheels. Quote Link to comment
racerx Posted March 23, 2010 Report Share Posted March 23, 2010 would spacers work? Quote Link to comment
benzo Posted March 23, 2010 Report Share Posted March 23, 2010 how close are you to rubbing. for me I got some ssr wheels and they hit the calipers but I ended up using my rotary grinder and just shaved a bit off the calipers and it cleared my wheels. if your wheels are rubbing so slightly maybe you can do the same Quote Link to comment
