Gumby 10y9 Posted March 15, 2010 Report Share Posted March 15, 2010 MY 72 510. I need a tranny mount for that, for some reason i misplaced the one i had. It has the 280 5 speed tranny, what mount will work? The original 4 speed mount or the 280 5 speed mount? And if any one has one I'm willing to buy it. Quote Link to comment
Gumby 10y9 Posted March 24, 2010 Author Report Share Posted March 24, 2010 So what's guys? What is the solution to a tranny mount from a 4spd to a 280 5spd, a typical swap? Mod? Thats cool, who has a pix? Should be simple, right. Help me out.Or who has a mount that that was used on their former swap and now has a k swap. Quote Link to comment
Bleach Posted March 24, 2010 Report Share Posted March 24, 2010 so you're putting a long L-series transmission in a Datsun with a short L-series transmission. it would require a custom mount and have a professional shop to shorten and balance the driveshaft. Quote Link to comment
Gumby 10y9 Posted March 25, 2010 Author Report Share Posted March 25, 2010 Driveshafts done, cut and shortened, and installed. all i need now is the tranny mount. so if u or any one has done this before, i need a already mod mount or specs on how to mod it. It's a typical swap and shoudnt be so complicated to get the answer. L18 motor wit a 5spd 280 tranny. Typical swap, just need the tranny mount info, and thanks for the response, any info is appresiated. Quote Link to comment
ppeters914 Posted March 26, 2010 Report Share Posted March 26, 2010 Dime Quarterly Volume 9 Issue 2: Tech How-To: 5-Speed Transmission Adapters -- Installing a 5-speed transmission in a Datsun 510 can be made easy. We can't help with the lifting, but Randy York shows you how to build adapters to mount that 5-speed transmission to your 510 using the stock 4-speed crossmember. Quote Link to comment
Gumby 10y9 Posted March 27, 2010 Author Report Share Posted March 27, 2010 Thanks!!! Quote Link to comment
