paradoxx Posted February 15, 2010 Report Share Posted February 15, 2010 At last got my GC coilovers......now I have a few questions. whats the correct height to install them. I know I have to remove the old spring bottom reatiner, but I have to weld the rings at the same height? Please shoe me the way, is my first experience with coilovers. Quote Link to comment
benzo Posted February 15, 2010 Report Share Posted February 15, 2010 if they are new they should of come with instructions but seems like they did not. what I do is cut off the stock spring perches and then grind smooth and then slide the weldable ring and then the sleeve and position the sleeves just under the threaded cap for the strut insert. the cap keeps the sleeve from moving. at this point position the weldable ring and mark or tack weld into place and then take the cap and the sleeve off and then weld completely and when completed paint and put all together. if you need instructions I can maybe fax them to you or get it scanned to email to you or contact ground control and they should be able to send to you Benzo 1 Quote Link to comment
paradoxx Posted February 15, 2010 Author Report Share Posted February 15, 2010 I really appreciate if you can get a scan for me :D Thank you! Quote Link to comment
